case 611b rear pto
chri
05-31-2004 18:22:58
well i got the 611 running after a couple of hours of tlc.i will be needing a carb kit for this. i believe it has a tvs 749 on it. my question is this the tractor was sitting for 7 yrs. it seems all the hydraulics work, leaks of course. the case-o-matics works fine. the rear pto would not engage. any suggestion prior to removing it. thanks chris
Rob
06-21-2004 08:45:30
 Re: case 611b rear pto in reply to chri, 05-31-2004 18:22:58
Chris, contact me about your pto if you have to dismantle it. I have a 611 project under way as well and would like to compare notes.
John Saeli
06-01-2004 18:36:57
Hey Chri: What exactly are the symptoms of that PTO? If you have absolutly nothing, it probably is disengaged completely. Just under the Top Link Shaft, off to one side, look for a 3/8 spool with a roll pin in it. That spool shifts in & out to engage & disengage the PTO ass'y. After the spool is engaged, then the hand lever is used to engage & disengage the clutch pack.
