Hydraulic leak on Vac 14
Case Vac Man
05-30-2004 09:12:59
I have a hydraulic leak on my tractor the leak seems to be on the fitting on the hydraulic line it seems to leak from the top of the fitting not the threaded end. Anyone know away to fix a problem like this? The line is either copper or brass can you not buy a regular hydraulic line for this one? Or do you have to try and find original one?
Joe (Wa)
05-30-2004 10:45:06
 Re: Hydraulic leak on Vac 14 in reply to Case Vac Man, 05-30-2004 09:12:59
Oil leaks out there because it is the path of least resistance on compression and metal-metal fittings. I think most of yours are compression.
Take the nut loose, if you can spin the ferrel with you fingers the tube is compressed as far as it will go and will leak.
Cut off the tube just above the ferrel, put a new ferrel on it, don't overtighten the nut and you are good to go.
Joe
Case Vac Man
05-30-2004 13:06:12
 Re: Re: Hydraulic leak on Vac 14 in reply to Joe (Wa), 05-30-2004 10:45:06
Thanks Joe I will give that a try. I could not for the life of remember what to call the end of those tubes.
