hard to start
Walter
05-29-2004 20:25:57
Case SC will not start using starter, I have to pull it off and when it does start it black smokes like its flooded. Once it starts it will run fine all day ,turn it off and try starting right back up and its the same thing won't start.Battery is good. I've changed the carb and no improvement. What's up? I 've heard that the mag fires differently once it starts turning over faster is this true? Could this be the problem or timing?
C. Amick
06-01-2004 10:10:23
 Re: hard to start in reply to Walter, 05-29-2004 20:25:57
If you think the mag is the problem, post a message for John Saeli. He sells re-built SC mags. As far as the carburetor goes, I always have to choke mine to get it started. If it starts when pulling the tractor without choking, the float in the carb could be set too high causing it to flood.
Coloken
05-30-2004 06:52:50
Just though of some thing else. These old mags will soak up water in the (bakelite)? Has it been out in the rain? Cover the mag with a plastic when washing.
Coloken
05-30-2004 06:45:28
Two things: First, the impulse of the mag should click each time. If not, it is wore and needs fixed. The inpulse "snapes" the mag at a faster rate to give a hotter spark. All so retards the spark so you don't get kicked when hand cranking. As soon as it speeds up, this no longer happens. Second, the float valve is flooding the carburator. Valve is not so bad as to stop it from running, but leaks and lets it flood when stopped. Or set too high. Could be a little of both---weak spark and too rich mixture.
Glenn FitzGerald
05-29-2004 21:38:35
My SC would only kick once in a while while turning the starter. When we pulled it it started but ran VERY poorly. The mag needed new points, condensor, cap, and to be charged. Improperly functioning magnetos can pull a lot funny tricks. However when rebuilt they will run almost indefinately with VERY little maintenance.
Russ
05-31-2004 17:58:25
 Re: Re: hard to start in reply to Glenn FitzGerald, 05-29-2004 21:38:35
Starts now & then: I agree with a little of each of these strings. Clean out the interior of the magneto with alcohol and cotton swabs to elimate
and carbon tracking discharges (you want maximum spark to each cylinder. Set up an aluminum wrap around the mag area with a 1000 watt heater and drive all the moisture out of the bakelite over a 3 or 4 hour heat up period. Make sure the carb float tang is adjusted to the proper level and that the float bowl is dry. (No gas inside the bowl assembly. Resolder the bowl joints it it has any pinholing. If worse comes to worse send the entire magneto assembly off to a reputable reconditioning business. When all is said and done check your spark condition in the dark of the night. Should be a real strong blue/white.
Walter
05-30-2004 04:58:09
I'm seeing a spark with the starter but it doesn't look good? its not blue its white. I figured it was ok I thought spark was spark and if it would run when pulling it should run with the starter.
thanks
Robert Pence
05-30-2004 17:44:08
 Re: Re: Re: hard to start in reply to Walter, 05-30-2004 04:58:09
The Case mags on the SCs are really hot when working properly. We farmed with two of them ('47 and '51), and I remember that if you pulled the wire off the plug, it would throw at least a quarter-inch blue spark with a quite audible snap. Get your fingers too close to the connector, and it'd about knock you on your butt!
As a teenager, before I became virtuous, I used to sneak smokes while working alone in the fields behind the woods. If I didn't have matches, I'd take a piece of corn husk or whatever other flammable material was at hand, dip it in the gas tank, and then pull off a plug wire to ignite it.
