case 540 clutch
Mike
05-29-2004 15:31:03
I've recently purchased a 540 with triple range trans that seems to have a clutch problem. When I put the tractor in gear it grinds. I've tried to adjust but with no luck.Can anyone tell me exactly how to adjust the clutch ? And how much to replace it ?
Dennis/Ohio
06-04-2004 00:27:17
 Re: case 540 clutch in reply to Mike, 05-29-2004 15:31:03
Hi Mike,
My 540 is the earliest clutch version with a bushing for a input shaft pilot bearing. I'm wondering if the pilot bearing is causing your problem and may loosen up with use?
The pressure plate finger height is adjusted when its installed. Hopefully that was done during the installation.
Dennis.....
Tom (Ks)
06-03-2004 18:01:19
The info I have is one inch free travel. Some 530's have a metalic clutch and they will grind some.
