VAC case front wheel question
Jerry W
05-29-2004 08:33:43
I recently bought a VAI front end that has the cast iron wheels.
My question - When did they quit using this wheel in favor of the wide hub 3 bolt wheel or the stamped wheel?
Or is it possible that my front end is off of a VC?
My plan is to put it on a 49 VAC.
Thanks Jerry
Robert Pence
05-29-2004 14:36:08
 Re: VAC case front wheel question in reply to Jerry W, 05-29-2004 08:33:43
My '48 VAC has cast iron front wheels, and I'm fairly sure they came with the tractor. Most of them that I've seen have similar wheels.
Jerry W
05-30-2004 18:00:34
 Re: Re: VAC case front wheel question in reply to Robert Pence, 05-29-2004 14:36:08
Robert Thanks for the reply. I found my parts book today that covers 1942 to 1956 VA,VAC,VAC-10,VAC-12,VAC-13,VAC-14,VAH and VAO and nowhere in the book are the wheels that I have. They have 3 or 4 other styles but no where do they show the one piece cast wheel and hub.
Although this frontend is from a VAI and my book does not cover it.
Jerry
Joe (Wa)
05-30-2004 18:21:38
 Re: Re: Re: VAC case front wheel question in reply to Jerry W, 05-30-2004 18:00:34
Jerry,
Are you talking about tireless cast wheels?
Joe
Jerry W
05-30-2004 20:29:52
 Re: Re: Re: Re: VAC case front wheel question in reply to Joe (Wa), 05-30-2004 18:21:38
Joe No, these are the kind that a person commonly sees on a VC. They carry a rubber tire. I think they are 4 spoke.
Jerry
Joe (Wa)
05-30-2004 21:32:19
 Re: Re: Re: Re: Re: VAC case front wheel question in reply to Jerry W, 05-30-2004 20:29:52
Ok, I just wondered. I don't have a parts manual that shows that wheel either.
Joe
