CASE Engine DC or CC
Kevin (FL)
05-29-2004 07:15:02
This question is coming from someone not familiar with Case tractors--we have all AC & Farmall. I have an 80 year-old friend that is giving me what I think is a CC model. Pictures were posted here last year. I can get a set of rings for a DC model for little or nothing--are the engines in these two tractors the same? What about the SC model engine?
bill
05-31-2004 09:04:35
 Re: CASE Engine DC or CC in reply to Kevin (FL), 05-29-2004 07:15:02
you can measure the bore without taking head off measure thriugh hand holes with STIFF wire bent to go ariund the rod have done it mant times
Bill
05-30-2004 06:29:10
Kevin, The std bore of the cc was 3 7/8 The early dc used the same bore but later models used 4 inch bore. There was even 4 1/16th aftermarket sleeve set offered. you almost need to have the head off to check the bore. I agree that once you have a good running cc that you would love it. My advice is take the cc and restore it, if you dont like it then sell or give it to a good home. Alot of engine parts will interchange in the cc and dc also you can bolt a dc engine in place of a cc if the cc engine is bad. good luck with the cc Bill
Robert Pence
05-29-2004 14:42:05
CC and DC engines are the same in most respects, but whether the rings fit depends on whether the engine has a standard bore size. Get a CC in good shape and running right, and you'll like it a lot. It's rugged and performs very well for a tractor of its era. It handles pretty nicely, too, compared with many of its contemporaries.
