case stationary power unit
Bob Jarbek
05-28-2004 20:33:04
I have a case 4 cylinder engine mounted on stationary feet with a hand operated clutch output shaft and serial # series 5100000SE.can someone steer me in right direction as to year made ,model,proper over haul manual,horse power.
replys greatly appreciated best regards Bobby J
JCmarleau
05-30-2004 19:08:27
 Re: case stationary power unit in reply to Bob Jarbek, 05-28-2004 20:33:04
I do have parts manual for this engine if interested my e mail is [email protected]
bobby j
06-02-2004 19:02:07
 Re: Re: case stationary power unit in reply to JCmarleau, 05-30-2004 19:08:27
JCmarleau,
I would like to thank you vrey much for the offer of your parts manual but I have already aquired a parts & shop manual for my case engine,
my regards, bobby j
Mike Schotte
05-30-2004 10:53:51
Hi Bob!
That's an interesting serial number! Is that the same number that's stamped on the left side block flange?
I wonder if this is the first unit produced in 1947. I would have assumed they would have started with 5100001 instead of 5100000.
Case stamped numbers by series, not model... so the first thing off the "S" line could have been your SE power unit, the second thing off the line could have been an SC tractor, third could have been an SO orchard tractor, etc.
Keep us posted.
-Schotte
Walter
05-30-2004 05:05:25
Sounds like it would be a 1947 model. Series "S" engine similiar to a S or SC engine in a tractor. I'd say it's approx. 30-35 H.P. depending on the bore size. I'd get an overhaul manual on ebay for a SC tractor and that should be what you need.
Bobby J
05-30-2004 06:51:17
 Re: Re: case stationary power unit in reply to Walter, 05-30-2004 05:05:25
Good morning Walter,
I would like to thank you for the info and I will follow up on that,regards Bob
