DB 990 Selectmatic Gear lube/ Op manual
Mike
05-28-2004 18:00:22
What weight gear lube is needed in a 990 David Brown with the Selectmatic Trans? Just picked up tractor, want to do complete fluid change. Also, how many quarts of lube? Also looking for operators manual for this tractor.
Elmer
05-29-2004 04:27:59
 Re: DB 990 Selectmatic Gear lube/ Op manual in reply to Mike, 05-28-2004 18:00:22
Transmission uses tractor transmission/hydraulic fluid. You can use any brand, there is nothing special about the tranny in that tractor to need a specific lubricant. A five gallon pail will do, check under the tractor for the hydraulic screen. It is directly under the shift levers. Selectamatic refers to the hydraulic system. If you need an operators manual, email me i can helkp you out but need more info on the tractor the 990 was built for 18 years.
