Need crankshaft spec. on VAC 195?
Keith-OR
05-28-2004 12:08:27
Need to mic crankshaft on a friends VAC 195? Do not have any spec. would appreciate all the help I can get on Main and rod bearing sizes.
Thanks Keith-OR
Bruce Nelson
05-28-2004 13:40:12
 Re: Need crankshaft spec. on VAC 195? in reply to Keith-OR, 05-28-2004 12:08:27
Keith, Standard Main size is 2.2490/2.2500 Rod journals are 1.9365/1.9375 Bruce
Mains..mic.ed
05-28-2004 18:09:20
 Re: Re: Need crankshaft spec. on VAC 195? in reply to Bruce Nelson, 05-28-2004 13:40:12
Bruce, looks like the mains have been turned to .020. I get a reading of 2.227 on all the mains. Rods journels mic at 1.939 every time. I don't do this enough anymore to be sure of my reading, so will take crank out to my machinist friend and get him to check my readings.
thanks for any feed back....Keith
Keith
05-28-2004 22:28:48
 Re: Re: Re: Need crankshaft spec. on VAC 195? in reply to Mains..mic.ed, 05-28-2004 18:09:20
Found my problem. took my mic. to a friend's, the 2 inch needed to be calibrated. Was off .0040, now crankshaft rod journals mic.at 1.935 with two different micrometers .0015 wear isn't bad. Close enough.
Keith-OR
05-28-2004 15:47:57
Thanks a lot Bruce. That is what I needed. will get his Crankshaft mic.ed for his the evening.I tried to do a search on the arcieves but seems they are still down. Again Thanks Keith
