case 611b
chris
05-28-2004 06:11:41
help i am attempting to start this tractor after its been sitting for 10 yrs. my question is where and if does the tranny fluid go. i noticed as you are sitting on the tractor, theres a dipstick by your right foot pedals, is the the dipstick for tranny. also does this same tranny fluid run the hydraulics. thanks chris
joe
05-28-2004 16:00:02
 Re: case 611b in reply to chris, 05-28-2004 06:11:41
There should be two fill holes. One for the rear end and one for the transmission. I also have a 611 B and mine sat for about 12 years until i fired her up this year and she runs great. I noticed that my transmission was slipping badly when the tractor warmed up so some advice for you is to replace the two oil filters on your 611. One is located up by the radiator and the other is located right underneath the battery tray. They are both identical and cost about 6 bucks a piece.
tim bynum
10-24-2005 18:20:40
 Re: Re: case 611b in reply to joe, 05-28-2004 16:00:02
hey joe,do you happen to have the part number for those filters?im needing to replace mine. thanks, tim
Dave
05-28-2004 18:24:20
My 611b sat for about 10 years & when I turned it over it bent 3 push rods.May want to remove the valve cover & check for stuck valves.
