DC rough run
ted
05-28-2004 04:55:07
I got one of my DC's running yesterday. The guy I bought it from put a fortune in new pistons, sleeves, rods, mains, valves, even a new radiator, but it just dodsn't run the way it should. It does seem to fire on all four,(most of the time) but it just is rough, not consistent. I played with the carb and tried adujusting the timeing by turning the mag (it didn't seem to make much difference except when the top was turned all the way from the block it would kill the engine) but it just lacks that DC "cackle" and misses when opened up. Also, it seems to run hot, about 200, It could be he put a high temp thermostat in it, but it also leaks oil out the front. The oil is not coming out of the front seal but pools up in the casting from the narrow front and then drips down in a steady stream when hot. I'm thinking he could be off a tooth on the timeing gears, as he probably had it apart. Any other ideas???
Don Rudolph
05-31-2004 07:21:08
 Re: DC rough run in reply to ted, 05-28-2004 04:55:07
Ted,
Are you using the old plug wires-they tend to be bad after this many years. Also- the fact that it runs hot suggests a timing problem. We had to move the spark plug wires one hole ahead on the DC LP mag to be able to get the timing right. Don't ask me why. Don
Robert Pence
05-28-2004 10:31:14
A failing condenser will cause erratic missing that gets worse as rpm increases, and eventually it won't run at all. If the point gap is way too wide, that could cause problems too.
Have you checked for air leaks around the intake manifold gasket and the gasket between carburetor and manifold? You can do that by putting a little oil around the joint and watching to see if it gets sucked in.
Dean Roberts
05-31-2004 06:45:43
 Re: Re: DC rough run in reply to Robert Pence, 05-28-2004 10:31:14
You might try a hoter plug. These tractors normally use a D16 (old nunber) but with the fuels of today I have found that a D21 (old number) works a lot better. As to the oil leak the front seal is a large felt seal and should have a flange with I believe 3 bolts that can be tightened to compress the felt and stop the leak if it is installed correctly.
