SLEEVE PULLER HELP!!!!
steve
05-27-2004 19:50:59
Does anyone know where I can get a sleeve puller for a cheap price. Ive got to pull the piston sleeves out of my case 300. Or how I can build one Im sure I could come up with something that would work if I just had some advice as how to build it?
C. Amick
05-28-2004 09:59:40
 Re: SLEEVE PULLER HELP!!!! in reply to steve, 05-27-2004 19:50:59
Where do you live? There might be someone close to you that might be willing to loan you their's.
Dave S
05-28-2004 01:04:35
Steve, sleeve pullers are costly and aren't used that often by most. I made mine out of 5/8 plate turned to 4 1/16th diameter. Then turned a lip about an 1/8th to fit in my 4" sleeve. Bored a 1" hole in center and got a piece of fine thread ready rod to pull with. Turned an other piece of 5/8 by 4 1/2" for the top with a 1" hole. I used grade 8 nuts on the bottom and to pull with. I also welded a nut to the top of the rod to hit with a hammer to jar them loose. And use 1/2 by 3" bar stock to raise top disk off the block.
