David Brown990A 3pt
DaveC
05-26-2004 09:41:06
The three point hitch on my 990A does not raise but the loader and external outlets work fine, any suggestions?
DaveC
05-28-2004 07:36:07
 Re: David Brown990A 3pt in reply to DaveC, 05-26-2004 09:41:06
Thanks for the followup Ritchie. I checked the cable and it is fine, When I opened the cover to check the cable connection I could see oil flowing when the control lever was pulled back to the raise position, I am not sure if oil should be flowing inside this housing or if the valve body is messed up, but I defintely have oil and action at the control valve.
ritchie leslie
05-31-2004 18:18:02
 Re: Re: David Brown990A 3pt in reply to DaveC, 05-28-2004 07:36:07
OK. Was the oil flowing when the lift lever was in the raise position or when the lift lever was pulled back as far as it can go into the bypass position (you should have heard the engine rpm drop as the pump kept running continuously)??
ritchie leslie
05-26-2004 10:02:20
This happened to me. In my case the control cable back from the 3pt top link to the hydraulic control box was broken. Replaced the cable and adjusted and all worked fine!
