Old plows
Bret
05-26-2004 04:06:09
I have 2, or 3 depending on how you count, old Case plows for my VAC's. A 2-12 Eagle and a set of mounted 2-way's, 12's I think, for the 48 VAC. I have had no luck finding replacement points for them. Without all the available numbers for points that will fit, I have to go with the numbers on my present points, which narrows the field a lot. Has anyone ever found a way to mount a "modern" type point and share to the older style frogs? Or a way to mount a modern frog to the old beams without welding? This also comes up for the horse drawn plows. High speed moldboards aren't perfect for horses, but their a lot better than nothing. There are a lot of good old plows out there that need points, landsides, moldboards etc. Any ideas?
caseman-d
05-27-2004 12:03:17
 Re: Old plows in reply to Bret, 05-26-2004 04:06:09
If your serious email me your part numbers and I will see what I can come up with. Depending on the part number and the model of the plow I have been able to cross some of the part numbers, I will be gone for a week and can check the numbers when I get back.
caseman-d
Bret
05-27-2004 17:41:23
 Re: Re: Old plows in reply to caseman-d, 05-27-2004 12:03:17
Thanks, I'll get the numbers and contact you.
