I have a Case Vac 1949 model that I trying to over
Nicholaus Sowde
05-25-2004 14:41:38
I have a Case Vac 1949 model that I trying to overhaul the engine. I have the engine down to the taking the crankshaft out. Do I need to mark the gears before I take the crankshaft out. Will it get it out of time when I take it out or what? Thanks
C. Amick
05-26-2004 10:06:19
 Re: I have a Case Vac 1949 model that I trying to in reply to Nicholaus Sowder, 05-25-2004 14:41:38
The gears should have punch marks on them. They are usually near the outer edge next to the teeth. I'm not sure about the VAC engine, but most of the time you will have a single timing mark on one gear that matches up to double punch marks on the adjacent gear. Better put Piston No. 1 on compression stroke and top dead center and look for the marks.
mike's600
05-25-2004 15:20:13
Set the engine TDC 0n number one compression stroke. index the timming gears if they are not marked.
