quandry?
Stick
05-24-2004 21:20:01
Have a choice of 3 tractors from the same seller..... Case 1030 diesel, Massey 90 diesel, and International 666 gas, all with loaders. What are the good and bad points of each?
Stick
05-27-2004 19:50:05
 Re: quandry? in reply to Stick, 05-24-2004 21:20:01
Well, I bought the Case 1030. I had the International 66 as a loaner for a month, and with gas at $1.00/liter CDN, I found it was just too expensive to run. It was my favorite of the 3, but I just can't afford that kind of fuel consumption. Our fuel rebate was just cancelled by the latest provincial budget, so now we're paying near pump price for fuel. Might have been ok just as a yard tractor just to handle big bales, but I need it to pull a 750 gallon water wagon and a mower, swather, tandem disk, rake and baler, as well as a fair sized hay rack. I have a 2N Ford I use for most of the small jobs, so the big boy will only be used for bigger things.
So..... .you'll likely be hearing from me once in a while as I get to know the new old beast.
Grumpy
05-26-2004 05:20:55
Get on each tractor for 10 or 20 minuts. Go back and forth turning and working the loader up and down. If you're going to use this tractor every day you want the one that is the most user frendly My guess is the 666 will win unless the gas engine is an issue. Stan
JDB
05-25-2004 10:22:20
We had an IH 656 gas with a loader on it. At that time we used to stack hay which is all loader work. It was a good loader tractor but we didn't keep it for more than a year or so because it was very thirsty. When it comes to tractors about this size and up, the diesels seem to be more economical to operate.
todd hamilton
05-25-2004 19:26:11
 Re: Re: quandry? in reply to JDB, 05-25-2004 10:22:20
Grandpa's 656 didn't burn near as much gas as Uncle Mike's 706 - now that was one thirsty tractor. It would haul a load of hay down the road in Hi 4th over 20 mph!:^)
kyhayman
05-25-2004 07:25:59
Just my personal biase (and I risk getting run off the Case Board) but I like the IH 666 for a more utility tractor kind of work. 1030's are ok but I think of them as a 'big heavy tillage tractor' Seem awkward for general use. Dont know anything about the MF 90 other than I think it is an older series and may lack some of the features.
kyhayman
05-25-2004 07:28:11
 Re: Re: quandry? in reply to kyhayman, 05-25-2004 07:25:59
Big OOPS here, I just reread and missed that the 666 was gas. Now I'm not sure I would want any of them. Still would probably rather have the 666 but a lot closer to the 1030. For me I'd take 'none of the above'.
Jim Handke
05-25-2004 06:17:58
We had 2 1030's at one point, and I recommend them over the others you listed. They will heat up to 200 degrees(and higher) under constant load. We had to remove the radiators and have the top tanks soldered. This won't be a problem if it's just a loader tractor.
Glenn FitzGerald
05-25-2004 05:15:51
We had a 560 Gas about 20 years ago. We thought it was expensive to operate then... I prefer the Case of your three choices but would rather have a 930 as the 1030 is noted for some heating problems.
