Case-o-matic 830 (Gas)
Randy Dressler
05-24-2004 18:50:10
Went to put it in 1st gear and it made a couple of clunks. The shifter had a quite a bit of play. I then tried reverse and it went in just fine, but now it will not come out of reverse. I removed the shifter and was curious how it should fit back in. I probably should have left it alone but...Any help would be appreciated.
Brent Behner
05-25-2004 18:45:25
 Re: Case-o-matic 830 (Gas) in reply to Randy Dressler, 05-24-2004 18:50:10
Randy Remove Battery & Board Under Gas Tank & Small Jack On Housing, Remove 3 Nuts On Steering Coloum To Trans. Cover & Hood & Raise Tank & Steering Coloum Off Trans Cover. Remove Trans Cover & Shifting Rail Assymbly & Repair Broken Shifting Fork. Weld End Of Shift Lever & Grind To Fit Slots. BRENT BEHNER
Randy
05-26-2004 04:07:48
 Re: Re: Case-o-matic 830 (Gas) in reply to Brent Behner, 05-25-2004 18:45:25
Thanks, do I need to remove gas tank or will I have enough room to work with by leaving it on?
