2290 powershift
kycase
05-24-2004 08:27:44
I am having a problem with the powershift on my 2290. With the tractor running and in park I have breaks and steering but no pressure to the remotes. With the clutch pushed in about 1/2 of the way down pressure returns to the remotes. push the clutch all the way down and it stalls the engin. Can anyone help and is this a commin problem. Thanks Dennis
Brent Behner
05-25-2004 18:30:18
 Re: 2290 powershift in reply to kycase, 05-24-2004 08:27:44
kycase Problem Exist With c2& c3 Clutch Packs Seperating & Oil Passing Directly To Trans Housing. C2&C3 Bolts Broke. Must Split Tractor To Repair. When I Repair Them I Bore Out Holes & Tapp To 7\16 Allen Head Grade 8 Bolts. Replace All Bellvell Springs & All Pistion Seals. While Apart Check Torque Limiter Clutch On Flywheel. P.S. Cut Heads Down On Allen Head Bolts & Replace The 3 Steel Seal Rings On Oil Distrubter. BRENT BEHNER
Shane
05-26-2004 05:39:23
 Re: Re: 2290 powershift in reply to Brent Behner, 05-25-2004 18:30:18
We had a 1270 do the same thing, shear off the clutch pack bolts. Unfortunately it ate up the clutches and we replaced it with a pack out of a '94 series one and I am sure it has 1/2" bolts rather than the 7/16" which are difinately better than the original 3/8"!
Shane
05-24-2004 14:47:25
Possibly a valve sticking in the powershift valve body. Take the caps off of the ports and pull the plunger out, make sure they move freely. Not sure if that would cause the remotes to lose pressure though but it might.
