How much oil in a new a/c system
Shane
05-23-2004 06:48:37
Our 1070 a/c compressor locked up, have the new one and after a system vacuum how much oil should I put in the compressor? The little tag with it says to check the vehicle recommendation and then add half that amount directly then half of it through the suction side once the system is operable.
Joe (Wa)
05-23-2004 11:21:48
 Re: How much oil in a new a/c system in reply to Shane, 05-23-2004 06:48:37
New compressors come with a full oil charge or specific instructions in type and quantity of oil. Check with the seller or manufacturer.
Do not put oil in the drier. If you find oil in a drier it came from the compressor. A small amount of compressor oil travels with the refrigerant in all systems. An excessive amount of oil in the drier or evaporator is an indication of low superheat in the tail coil of the evaporator. Liquid that is not vaporized in the evaporator returns to compressor crankcase, vaporizes and carries the oil into the system. This leads to compressor failure.
Superheat in a properly charged system is a function of the device used to meter the refrigerant into the evaporator. If the metering device is an expansion valve and not the adjustable type, it should be replaced.
If capillary tube(s) expansion, the system is simply overcharged with refrigerant if the superheat is too low and undercharged or capillary tube(s) are restricted if too high (more than 10 degs).
Overcharging is a frequent occurrence in R-134 system due to the lower efficiency.
Superheat in a properly charged system should be 2-4 degs for full evaporator efficiency and cooling of the compressor w/o flooding the oil out of the crankcase.
Joe
Joe (Wa)
05-23-2004 16:52:11
 Re: Re: How much oil in a new a/c system in reply to Joe (Wa), 05-23-2004 11:21:48
In a new system, the initial compressor oil level will always be slightly higher than operating level. That is calculated for the oil that is predicted to travel with the refrigerant. You may have to top-off the oil in a new system via the suction.
When installing a new compressor on a used system the oil level can not be predicted because the amount of oil present in the old system is unknown, I.E. if the superheat is very low, the majority of the oil leaves the compressor and it fails. This oil ends up mostly in the drier/receiver and in the evaporator.
When you put a new compressor on this system, most of the excess oil will return to the compressor resulting in a dangerously high oil level.
Renewing the drier/receiver and evacuating the system will remove some but not all the excess oil. To remove it all you would have to do a flush.
The way your post reads, the compressor maker wants you to add oil up to a fill plug on the crankcase (do you have a plug?), do an initial run and adjust the oil level up via the suction or down via the plug to compensate for the unknown quantity of oil already present in the system.
There may be some confusion in the use of the word "top-off" as opposed to adjust. You may want to contact the manufacturer and clarify the instructions to be sure.
Joe
Shane
05-23-2004 14:55:39
The sticker on the pump specifically says it comes with only assembly oil and needs oil added. The info sheet says to add oil into the compressor and to add some through the suction side. I need to know how much to add directly and how much to add through the suction port. If I remember right it was about 12 ounces total.
Jerry
05-23-2004 09:58:04
Shane, Check with the dealer and he will give you the correct amount. If you change the compressor you should change the dryer also,AND ADDD OIL TO THAT. Also are you changing the system over to R134 A? If so you should flush the system.I hope this helps you .Jerry
