Zenith Carb leak
bill
05-22-2004 22:44:01
Occassionaly, maybe more often than not, the carb on my G320 utility leaks fuel, seems to come from a circle indent on the bottom of the I believe Zenith carb.
Does'nt leak when running - what's the problem - stuck float? its a gravity fed system.
any solvents going to help or do I need to rebuild?
Dave
05-23-2004 05:57:17
 Re: Zenith Carb leak in reply to bill, 05-22-2004 22:44:01
Bill,
That little circle is actually, when all the dirt is cleaned from it, is a small porus disk used for such a purpose, excessive fuel to leak out. I am sure that your needle and seat assembly is, 1. either has some dirt in it
2. is in need of a rebuild.
The reason it doesn't leak when running, is that the fuel consumed keeps up with the amount of fuel leaking in.
good luck,
Dave
