forklift electric motor
Bill
05-22-2004 13:04:54
I know its off case subject However do any of you fellows know where I can get an electric forklift to part out to play with making a ford ranger into an electric One with the large batt would be nice A friend got a working unit at auction last month for $100.00 and I stayed home to watch the NASCAR race that day
Paul Janke
05-23-2004 06:41:33
 Re: forklift electric motor in reply to Bill , 05-22-2004 13:04:54
Bill, not what you are asking here, but I will look for that missing part, or is it something which is there but is bad? I don't mind getting the parts back if you can't use them, but I would hate to have to give your money back, it's already been spent (grin). Paul
bill
05-23-2004 09:22:18
 Re: Re: forklift electric motor in reply to Paul Janke, 05-23-2004 06:41:33
its about 3 inch Outside diam. having extenal fine threads . It has a seal assebly of about 2 or more inches intrnal diam it screws into the main converter housing next to the plate which the clutch bolts on The large plate the clutch facing presses on and the pressure plate boltd to has to be sealed from oil leakage from the converter body this part is that seal assembly which threads into the actuaol converter Hey I never thought about a refund!!!! I can see why the first guy had so much in the clutch as the thing has been machined and other parts all new I can mail you a coy of the service manuel fot your machine as well as showing a pict of the seal assembly
Paul Janke
05-23-2004 10:10:17
 Re: Re: Re: forklift electric motor in reply to bill, 05-23-2004 09:22:18
A copy of the service manual would be appreciated. I will try to look for the other to send to you. It should be light and inexpensive to send. I still have your phone number if I need to call you. Paul
