Case DI ?
Matt H.
05-22-2004 10:00:21
I was recently given an old case tractor. I dont know a hole lot about them. It looks like there was a tag under the tray for the battery but there is only 2 rivets left there.I was told it is a model DI but dont know much more then that. Can someone tell me how to find out. It says case on the front and has a fancy radiator cap.I can also say it is really really heavy.The motor is stuck but i suspect it is from water coming in the muffler. Is it a model worth even starting to look at or just leave it as a conversation piece. Any info will help, thanks
Robert Pence
05-22-2004 16:01:57
 Re: Case DI ? in reply to Matt H., 05-22-2004 10:00:21
The way you describe it, the battery mounts behind the gas tank, above the steering column and instrument panel. That would make it a D series. S series tractors had the battery under the gas tank, at least the ones I'm familiar with.
Guys, didn't the industrial models (DI, SI) have some sort of a flat front end, rather than the streamlined grill that the ag models had? The D series ag tractors had a cast iron grill, and the S series ag tractors had stamped steel.
Matt H
05-22-2004 17:50:46
 Re: Re: Case DI ? in reply to Robert Pence, 05-22-2004 16:01:57
I checked were mike said to check for numbers and i found 5219451DI. Yes the battery is behind the tank and the front end is flat. any idea what year or horsepower the beast made?.
DCTOM
05-22-2004 16:36:41
YOUR RIGHT ON ALL COUNTS BOB
mike's600
05-22-2004 14:37:23
Hey, with the fanncy radiator cap, you might have a S series (SI) . Look on flywheel housing (carb side) for serial number stamped into edge of the housing.
