VAC-14 questions year and oil filter question
jdemaris
05-22-2004 09:58:33
I bought a VAC-14 this morning for $580. I've already got a couple of VACs (not 14s), but this VAC-14 is different. Steering is different for one thing. Steering gears seem to be in the front. Steers much nicer than my VACs. Eagle hitch works nice, and generally speaking the tractor runs good. The guy told me it hasn't had any oil in the oil-filter for years. We pulled the filter off with the engine running, and sure enough - it's dry. Engine carries 20 lbs. of oil pressure though, at hot idle. Obviously, something is amiss. Anybody know what year this tractor is? Tag reads: VAC-14 5755483
Joe (Wa)
05-22-2004 10:36:12
 Re: VAC-14 questions year and oil filter question in reply to jdemaris, 05-22-2004 09:58:33
Serial nr is 1953 model.
Some people blind off these oil filters when the oil inlet stem is broken off or missing. Take the housing loose from the block, may be a piece of sheet tin or similar over the gasket area.
Joe
jdemarisj
05-23-2004 07:55:20
 Re: Re: VAC-14 questions year and oil filter quest in reply to Joe (Wa), 05-22-2004 10:36:12
Thanks, I'll have to study it a bit when I get around to it. Someone hooked up an oil line to the valve cover, I guess to lubricate the rocker arms. So, I suspect the dry oil filter is part of a problem that also resulted in dry rocker arms.
Joe (Wa)
05-23-2004 12:42:38
 Re: Re: Re: VAC-14 questions year and oil filter q in reply to jdemarisj, 05-23-2004 07:55:20
Blinding the oil filter will provide full oil pump output for engine lubrication rather than having a portion of the oil output pass through the filter and back to the sump.
The specs for this engine state that the oil press should be 12-20 psi with the engine at operating temp and at full rpm. I am not saying that your 20 psi hot at idle is too high but coupled with a lack of top deck lubrication it is suspicious.
Lubrication for the valve running gear, center and aft cam shaft bearings is provided up through the center rocker arm support and is distributed via the rocker arm shaft. The shaft is two piece, ends meeting under the center support. The shafts are hollow with one oil hole under each rocker arm bushing. The oil holes must be facing toward the valves to provide sufficient lubrication to the valve running gear and the above cam bearings. Each rocker arm bushing has a hole at the top. When the rocker arm rotates down to open the valve, the hole in the bushing moves closer to the oil hole in the rocker arm shaft, relieving some of the flow resistance. In a higher oil pressure system you may even see a spurt of oil when these two oil holes are near alignment.
Simply put, the rocker arm shafts must be installed with the oil holes facing the valves. If rocker arm bushings are replaced, the hole must be at the top.
Joe
