smokin starter
ron
05-22-2004 05:19:52
my Case tractor backhoe stalled yesterday. when i attempted to start it again it fiered up just fine but two seconds later it stalled again (it did this again many times). the starter motor was grinding as well so i took it off to take a look but i dont think that has any thing to do with it stalling.
Dave
05-22-2004 07:27:15
 Re: smokin starter in reply to ron , 05-22-2004 05:19:52
Ron,
could be a fuel delivery problem.
Dave
Ron Aguonie
05-22-2004 09:59:24
 Re: Re: smokin starter in reply to Dave, 05-22-2004 07:27:15
"Hi" Ron here. My son Aric put about 2 gallons of old fuel (7 months), could that be the problem? The tractor is sitting on an angle with the back left wheel sitting in a hole up to the back axil. Could this be hampering the fuel flow? I called Les (previous owner)and said to check 2 cylinders that resemble oil filters on the fuel line, to remove the bottom screws and see if water comes out. Is this how you would check for fuel problems. Could I also put some gas line anti-freeze in the tank to dry up any water?
Thanks for your help in solving this problem.
Ron
