411B
John Nelson
05-21-2004 19:40:12
A friend of mine has a tractor with a Caseomatic, 411B, as far as I can tell the converter clutch never releases. I did a search of the archiives and it sounds like the converter is very expensive to work on and parts very hard to find? I did learn a lot and the archives were very helpful. The clutch pressure and converter pressure are normal. The direct clutch seems to work ok. It's a nice machine, I hate to see it scrapped. Any ideas.
John
john nelson
05-22-2004 05:57:12
 Re: 411B in reply to John Nelson, 05-21-2004 19:40:12
Thanks, it's in central oklahoma. With the converter operating, and trans in gear, at lo idle, I should be able to hold the brake to stop tractor without stalling the engine? Also I can't ever feel it change when I move the lever. John
John Saeli
05-22-2004 20:12:28
 Re: Re: 411B in reply to john nelson, 05-22-2004 05:57:12
Hey John: You are correct. You should be able to hold it with the brake. Like I said before, check to be sure the oil is thin, not heavy gear oil. Make sure the spools that work with the clutch pedal & hand lever are working correctly.
john nelson
05-22-2004 20:28:38
 Re: Re: Re: 411B in reply to John Saeli, 05-22-2004 20:12:28
Thanks for your help, he has been using dextron3, and I checked to make sure the spool valves are working, today he called and said if I was game go ahead and tear it down, so i may be holleren again. I've been into several other's but not one of these. I do have an I&T manual and a good Case-IH dealer nearby. It's a pretty clean LPG trator.
thanks John
John Saeli
05-22-2004 04:48:53
Hey John: Where is this tractor located? The most common reason for the convertor not "releasing" is that the discs get warped. Could also be something simple like the wrong oil being in there. Should be a thin oil like Hy-Tran, or the CASE TCH oil. I just rebuilt a Converter in an 800 and all the parts were available. Like everything else, nothing is cheap. I have never seen a converter that didn't "drag" a little, so I always start them in gear so I don't have to crash them in after.
