VA distributor grease thing
John Mc
05-21-2004 05:55:20
I need to replace the seal around the grease thing (where you add grease for the dist shaft). Was the original leather? What can I replace this with? Looks like the old one was made on. By the way, what is the correct name for this thin?
John Mc
05-21-2004 12:41:28
 Re: VA distributor grease thing in reply to John Mc, 05-21-2004 05:55:20
No, what I am refering to has a small threaded cap that is filled with grease. When you tighten the cap a round or so, grease is squeezed into the distributor shaft bearings. The grease cap screws onto a fitting that has some sort of seal to keep grease from leaking around the threads, I presume. This is the seal I am wondering how to replace.
Joe (Wa)
05-21-2004 14:24:13
 Re: Re: VA distributor grease thing in reply to John Mc, 05-21-2004 12:41:28
Ok, what you have is a manually operated grease cup. These used to be standard equipment on electric motors and small bearings.
I have not seen one with a seal. If you get grease out of the threads when you rotate the cap, there is probably a restriction (hard grease?) or the bearing is already full.
Click on the link and type "grease cup" in the search window and scoll down near the bottom of the page when it comes up.
Joe (Wa)
05-21-2004 12:36:04
Some older distributors have a felt wick ring that looks like a seal. The felt absorbs lubricant from the grease cup or oiler and wicks it to the bearing.
