Case 310 engine problems
steve
05-20-2004 19:18:03
I just did a valve job on my case 300 and installed a new head gasket when I put it back together and torked it down to specs. The problem is that after about an hour or so running the engine, oil is leaking out of the spark plug hole and it cotinually fouls plugs with lots of oil on them. Could this be the rings because I did not replace them. What ever the problem is I need to fix it Thanks, Steve.
Butch/ OH
05-20-2004 20:11:04
 Re: Case 310 engine problems in reply to steve, 05-20-2004 19:18:03
Are you sure the oil isn't coming from around the base and top of the push rod tubes that are between the spark plugs? It's unlikely that oil would be getting out of the spark plug holes. Those tubes have an o-ring that seals them to the casting at both the top and the bottom. Most machine shops dont pay any attention to them and if they hot tanked the head they probably ruined what was left of those o-rings.
CASEPOWER
05-20-2004 19:54:43
Rings is my best guess. Increase in cylinder pressure with good seating, correctly adjusted valves will cause problems with warn or weak rings. Does it have any blowby from the dipstick tube or oil fill??
