VA tractors
pasbon
05-20-2004 12:50:57
I have located 3 va tractors, 2 va's and one vai are the parts interchangeable? one va is for parts and the other doesn't have much compression, the vai started having a knock and he shut it down. the two va's have the eagle claw 3pt hitch and the vai only has a drawbar. the vai motor is stuck and the parts tractor is stuck. the sheetmetal has some rust through and the tires need help. He said make an offer and I was wondering what they are worth.
Art
05-21-2004 06:52:55
 Re: VA tractors in reply to pasbon, 05-20-2004 12:50:57
I have a 44 VAC, a 46 VAI, and a 52 VAC. Most of the parts are interchangable....Exceptions are due to up-grades over the years..Example: none of my tractor has the same size rear tires. Also the VAI should have a diffrent tranny.and the guts to the motor are going to be a little diffrent. My VAI has cast iron, or steel pistons. The Vai's engine rpm's it rated higher than a VAC also, which makes the pto drive faster than it should. you should power back to run any impliments on a VAI. Other things that changed over the years is the stearing, and front grill. in 52, they went to a new style of stearing w/ a universal joint in it to keep it close to the motor, and this resulted in a longer hood, and a diffrent grill. All in all if you stay in a range of a couple of years, you should be ok...Just keep in mind that the bigest changes were made in 52 and forward...Hope this helps
