Dang, bad morning
Coloken
05-20-2004 12:50:40
Picked up a 6 foot KingKutter 3 point disk. Replaced 4 bearing and touched up the paint. Went out this morning to hook it to my 300 round nose and disk the garden. Not room on the 3 point pins for the Case eagle/quick coupler. Pins are only 2 inches front of the angle iron. I do like the Case quick hookup so guess I will have to weld extensions to the disk. Unless some body has a better idea. Must have been designed for a stuped Ford where the arms swing. I did get it working by using a rod behind the Case latches though. Hope the sweet corn comes up.
Chuck MA
05-21-2004 21:21:40
 Re: Dang, bad morning in reply to Coloken, 05-20-2004 12:50:40
Build a platform tilting back disks 45 to 60 degrees higher than front. I used old railroad ties. Works with my 300 round nose with eagle hitch and lienbach 3 pt disk.
C. Amick
05-20-2004 13:29:57
Would flipping the pins around to the inside help?
I had this problem with a rear blade. I ended up heating the angle iron flange and bending it to make room.
