DB 1200 Hydraulics
dale armstrong
05-20-2004 06:19:21
I need our knowledge. My 1200 Slectomatic has set all winter (minnesota) and now I get no hydraulic output at all on either the three point or the loader. I have moved every lever switch and button
Brian M.
05-20-2004 07:49:45
 Re: DB 1200 Hydraulics in reply to dale armstrong, 05-20-2004 06:19:21
I have had the same problem with mine. What's happening with mine is that it is sucking air in somewhere (bad seal or o-ring??) I have been told that the pump is probably bad. The quick fix is to crack open the big compression fitting underneath the tractor in about where your brake pedals are at, let the tractor run until you get a nice steady flow again, then shut the tractor off and quickly re-assemble the fitting. The funny thing is since I have started the spring chores, I haven't had to bleed it for about 2 months now. Maybe you have the same problem. Hope this helps!!
