930 case questions
Jim in michigan
05-19-2004 14:19:27
Guy wants me to work on his 930,, seems the ignition switch doesnt do anything, also even with the switch off the batteries go dead,, could this just be a bad ignition switch,, I havent looked at the tractor yet, so I am just looking for ideas before I drive the 30 miles to check it out,,Thanks,,,Jim
Ryan
05-20-2004 21:41:17
 Re: 930 case questions in reply to Jim in michigan, 05-19-2004 14:19:27
Batteries you say? I would make sure you don't have one going bad on you and pulling the other one with it? Just a thought, I have had it happend before....
Ryan
MGM
05-20-2004 10:10:12
Take a screwdriver and arc across the solenoid from the battery terminal to the switch terminal also located on the solenoid, small terminal, if it goes its your switch or the wiring from your switch to the solenoid, did you get a voltmeter and check the voltage on your battery and right on the termanal of the solenoid also. Good luck
MGM
Jerry
05-20-2004 19:36:35
 Re: Re: 930 case questions in reply to MGM, 05-20-2004 10:10:12
MAKE DANG SURE THE TRACTOR IS OUT OF GEAR WHEN YOU JUMP THE SWITCH WIRES AT THE SELENOID. We lost our milk hauler doing this
Jim in michigan
05-20-2004 12:46:27
I was planning on jumping it at the selenoid,, just havent made it to where the tractor is yet,, havent had time,,I was just looking for ideas before I went...Thanks,,,,Jim
DKase
05-19-2004 21:09:34
Diesel or gas? Won't start, or no power to anything? Should be simple to check out the switch.
Jim in michigan
05-20-2004 06:37:56
 Re: Re: 930 case questions in reply to DKase, 05-19-2004 21:09:34
diesel, from what he said there is no power at all, I am thinking either a switch or starter selenoid,, Jim
