800 case
Dave W
05-18-2004 19:26:26
I'm parting out an 800 case and need to know if the power steering gearbox and the hydraulic pump will interchange with an early model 830.I also need to know if the radiators are the same. Thanks in advance Dave
Jim B
05-19-2004 18:38:57
 Re: 800 case in reply to Dave W, 05-18-2004 19:26:26
Dave, Is the 800 a Diesel C-O-M ? If so, what are you going to do with the complete Engine, radiator, fuel tank, starter, ect? I'd like to consider converting my early 830 Gas to a Diesel.
Patrick (Mich.)
05-19-2004 10:05:22
Dave, I believe that the gearbox will interchange with 830 models built through May 1961. The hoses are routed on the right side of the tractor on the later ones. The pump should be the same through January 1960 of production, being mounted on the LH side of engine. After the pump was switched to RH mounting, I don't know if it continued to be the same housing with only different mounting brackets.
Tim
05-18-2004 20:17:59
Dave,
Can't help you at all with your question. But I'm restoring a 700 and need the following: seat, grille screens, fender, maybe a rear rim, battery cover, radiator cap. Do you have any of the above in good condition? Where are you located?
I'm sure one of the experts can answer your question. I believe the 400, 700, and 800 were somewhat interchangeable, but not the X30's. Good luck.
Thanks,
Tim
brent
05-19-2004 19:43:30
 Re: Re: 800 case in reply to Tim, 05-18-2004 20:17:59
Tim,
I can help you with some of that stuff. Email me and we can discuss it. I have some 830 parts that may fit what you need. We are in NE Ohio
Brent
Tim
05-20-2004 09:48:17
 Re: Re: Re: 800 case in reply to brent, 05-19-2004 19:43:30
Brent,
You blocked your address, can't e-mail you. Drop me a line at [email protected]. I'm not too far away - Central NY.
Tim
Dave W
05-19-2004 15:44:41
I'm in central lower michigan.
Dave W
05-19-2004 15:40:57
Tim, I have the grille screens. send me your email and I will email photos.
