Case 580 CK
Ross
05-18-2004 04:13:43
I've recented acquired a Case 580 CK circa 1971 (I think). I'm new to the concept of Shuttle tranmissions but had some success in restoring forward and reverse movement after replacing the pin and cam follower bearing linking the clutch pedal to the spool valve on the LHS of the shuttle spool valve. I've managed to refer to a page from a service manual which states there should be 3.1" distance between the mounting bracket bolt and the centre of the cam following shaft. All seemed well and movement was achieved in forward and reverse through all gears.
I've recently had to scale a small incline , no more than 10 degrees and without load. I found that the forward motion significantly dropped off. I was something like you would experience if you had severe clutch slippage in a car going up an incline.
Can anyone offer any suggestions as to the cause. It all seems fine on flat ground although when moving the shutttle lever it seems to take 3-5 seconds to respond before moving inthe appropriate direction.
RoyG
05-18-2004 15:16:38
 Re: Case 580 CK in reply to Ross, 05-18-2004 04:13:43
Just a torque converter drive. You don't have a problem
