Spring Fun in Montana
Tom Railsback
05-17-2004 19:34:44
Spring is finally here in Big Sky Country and that means tractor hauling season is also here. Over the weekend I got in on two hauling jobs, one for my best friend and one for myself. Saturday we took my F350 and gooseneck plus a semi-lowboy set uop and went about 35 miles East of Great Falls to pick up a TD14 with dozer and a
Farmall M, neither of which ran. luckily, we had a nice little TD9 as our helper tractor and it moved the TD14 although it was quite a load for it. We ended up pushing the 14on backwards downhill. The M was easier since we had a cable and snatchblock along. No major problems other than having to make an extra trip because the TD9 would not fit on the trailer with the TD14 and I couldn't begin to haul it wwith my f350.
Then yesterday, I went the other way and piccked up my 1939 DC4 which I had left at our club's showground over the winter. After I choked it long enough, it started and ran as well as ever. It's in the shed now waiting for me to need it for something like our upcoming tractor drive although I'll probably use the S because the DC tends to heat a little bit. I suspect I need to pull a couple of sleeves and clean some rust out of the block. I hate to think of that because the old thing runs so well other than heating.
caseman-d
05-17-2004 20:20:18
 Re: Spring Fun in Montana in reply to Tom Railsback, 05-17-2004 19:34:44
Tom,
Not sure what would be easier, but you could pull the waterpump out and flush it out good that way. You would probably have to pull the radiator but it would save you from opening up the engine.
I would think the TD14 would of been a load itself. Glad the trailer was big enough, you could of always found a Chevy to pullit for ya lol :):):)
caseman-d
Tom Railsback
05-17-2004 20:52:46
 Re: Re: Spring Fun in Montana in reply to caseman-d, 05-17-2004 20:20:18
I tried to pull the water pump about 12 years ago and I could not budge it so I stopped before I broke something. I didn't have a torch so I could not heat it and I still don't have one. Maybe someday I take it to a friend's shop and use his.
I agree on the truck but the F350 was the only thing I could find with a manual transmission last year when I was ready to trade. Now that I've had to put a $4250 transmission in it, I think I know why the previous owner traded it off. Oh well, live and learn.
jal-SD
05-18-2004 06:49:31
 Re: Re: Re: Spring Fun in Montana in reply to Tom Railsback, 05-17-2004 20:52:46
Tom, we've used both draino & washing soda in the radiator of a couple of DC's & CC's to clean out the rust in the cooling systems. Works pretty good, we think. We run straight water & a 1/2 can of draino in them until they are warmed up, then drain the mess out. (You gotta be careful with the draino.) Leave her set overnight & repeat the process. (Seems to loosen the junk up by setting overnight.) You might have to do this a couple of times, then use about 1/2 to 3/4 cup of washing soda a couple of times until water clears up. Might work for you & save pulling it &/or the radiator apart. We've also wired the round magnet off an old magnetic mount CB antenna into the radiator to collect chunks of rust, you'll be suprised how much you get. Give it a try. Make sure the timing is OK, if its off a little, it'll make these old girls heat, but I'm sure you knew that. (My $0.02 worth. jal-SD)
Tom Railsback
05-18-2004 17:48:14
 Re: Re: Re: Re: Spring Fun in Montana in reply to jal-SD, 05-18-2004 06:49:31
Thanks, jal. I'll try it.
