430 PTO adjustment
Ben
05-17-2004 06:01:52
does anybody know how to adjust the pto clutch on a 1969 430 it works fine until under a load
Tom (Ks)
05-19-2004 20:58:44
 Re: 430 PTO adjustment in reply to Ben , 05-17-2004 06:01:52
Disengage PTO lever,remove pipe plug from Pto housing. Use a flashlight to find the spring loaded lock pin. Insert a screw driver into hole to hold the lock pin IN as far as posible, while holding the pin in, turn the PTO shaft counter-clockwise until the pin will engage again. Try it one notch.
