Case 530 Transmission oil, what kind,check running
Dale
05-15-2004 03:30:57
I have purchased an old Case 530 CK with loader and back hoe. Machine runs great and operates well. I notice the high gear seems to slip to get moving and surges occasionally.Low gears work well.I would like to change the fluid and filter before I use machine but don't know what kind of fluid goes into this -O-Matic Tran.Do I check fluid levels while machine is running or shut off.Any info on this would be of great help.Thanks
Brent Behner
05-16-2004 09:40:15
 Re: Case 530 Transmission oil, what kind,check run in reply to Dale, 05-15-2004 03:30:57
Dale On this Old Tractor Use Case IH Hy Tran. This Oil Is More Of A 20 Weight. Book Says To Use Case t.c.h. Might Be To Light In Summer Work. Check Oil Level With Engine Idling. Oil Then Is Being Pumped To Oil Cooler Under Radiator & To Filter. Brent Behner
Dale
05-17-2004 13:18:32
 Re: Re: Case 530 Transmission oil, what kind,check in reply to Brent Behner, 05-16-2004 09:40:15
Thankyou Brent, I appreciate you taking the time to answer my question. I will probably only be using this machine during the summer seasons so of course this advise is very helpful....thanks again!!!
