VAC Eagle Hitch
Jerry W
05-14-2004 19:49:31
I recently purchased a rough 1950 VAC for the Eagle Hitch. When I campared it to my 1949 VAC that I intended to put it on I see a lot of differences in the rear end housing and the torque tube.
My question is - is this a difference in the years of the tractors or the difference between Eagle Hitch and non Eagle Hitch tractors?
Also what year was the first for the Eagle hitch.
Can anybody provide me with a picture of a CASE VAC mounted 2-14" plow. There is a mounted plow that came from the same farm but I could find no marking on it.
Thanks Jerry
David
05-15-2004 21:33:29
 Re: VAC Eagle Hitch in reply to Jerry W, 05-14-2004 19:49:31
Some of the houseing are not strong they will crack make sure your is good
wheat straw
05-15-2004 17:04:24
Jerry,
They were made both ways in 49. Erb and Brumbaughs FULL STEAM AHEAD has conflicting info on this. They say it started at # 5371000 but than on page 329 they show the starting and ending #'s to be 5300001 and 5317004. Oh well. there were both in 49.
Have a good one.
Wheat Straw
jimmy z.
05-14-2004 22:52:24
JERRY, i have a '49 vac w/o the eagle hitch and there probably is a difference in the rear casting. i'm quite sure the eagle hitch started in '49, however i've seen and heard of some w/o. i also have a two bottom mounted plow- i can't provide a pic., sorry. i am looking for someone in my area of erie, pa who has this setup, so i can check it out- all the sudden mine lines up "off center". nothing bent or twisted- just can't get the beam frames to mount right. it still plows ok, however. best of luck to you on this endever! jimmy z.
