DC compression check
BasketCASE
05-14-2004 15:02:41
My DC is testing compression like this:
#1 75 lb
#2 85 lb
#3 75 lb
#4 75 lb
The #3 plug is fouled and the #4 plug is fouled and oily. What should my compression be? Do I need a set of rings? Or do I just need a new head gasket?
DKase
05-14-2004 16:48:26
 Re: DC compression check in reply to BasketCASE, 05-14-2004 15:02:41
That seems on the low side to me. Mine runs just above 150# with a 5505 head. Right on 100 with the 5576 head. You might want to try a couple squirts of oil in each cyl. and see if that brings the compression up. It might be that your compression rings are OK, but your oil rings are bad. If you get plugs that are in the heat range of the D21, or D23 Champion might solve your problem. LOL DK
