Batteries
Russ
05-14-2004 13:54:40
I recently purchased a 1956 VAC and the battery has gone dead. It was suggested to me that I should replace the 6 volt battery with an 8 volt battery for a little more giddy-up in the cold WI winters. Will I goof the electrical system up by doing this? Thanks in advance -- Russ
Bill
05-15-2004 04:49:13
 Re: Batteries in reply to Russ, 05-14-2004 13:54:40
Russ, As the other posts have stated, Have good battery cables and a good starter and I never have problems starting a vac in wisc. I use a napa battery number 7244. Bill from Wisconsin
John Saeli
05-14-2004 18:30:17
Hey Russ: With New & Proper size battery Cable, Clean Connections, and a good 650CCA @ 0 Degrees 6V battery, your VAC will start in the cold. Cable size should be a minimum 1 Guage, if not larger.
C. Amick
05-14-2004 14:05:06
For what it's worth, it seems like the automotive electric shop guy told me that a problem is created by trying to charge a 8V. battery with a 6V. charging system.
