case 400 with eagle hitch
Bruce
05-14-2004 06:55:55
how much does a case 400 gas weigh with eagle hitch and fluid in tires without fluid in tires?
bill koob
05-15-2004 13:18:08
 Re: case 400 with eagle hitch in reply to Bruce, 05-14-2004 06:55:55
5563lbs with narrow front 12-38 rears without fluid. The fluid is variable..depending on mix.
Larry
05-15-2004 05:50:31
Each tire should hold about 55 gallons if full. If the fluid was mixed right it will weigh about 10 lbs./gallon.
mj
05-14-2004 15:46:48
About 4300 lbs. without fluid...with fluid ??? don't know.
