switching to alt on an 830
casey
05-14-2004 06:12:55
my friend just got a 830 and wants to change from a generator to an alternator. what does he need to do as far as wiring it up?
thanks in advance.
casey
Nick Nicholson
05-14-2004 16:09:20
 Re: switching to alt on an 830 in reply to casey, 05-14-2004 06:12:55
I changed to an alternator on my '56 model 310. Used a GM single wire alternator. No changes to any of the wiring, since the alt. goes direct to the battery. I later added an ammeter. Starter is still the 6 volt unit. 12 volts won't hurt it. It just draws half the current on 12 v.
Roger (Mi)
05-18-2004 05:22:59
 Re: Re: switching to alt on an 830 in reply to Nick Nicholson, 05-14-2004 16:09:20
You're right about suggesting the GM alternator. It's the best choice (single wire hookup). A 6 volt starter will draw a little more current on 12 volts but will spin twice as fast.
Shane
05-14-2004 13:46:09
Use a one wire self exciting alternator, it goes straght to the battery to charge it. I am sure you could wire up the ammeter or voltmeter to work also.
Jim B
05-14-2004 11:46:03
I put a older Ford Alt with external Reg. on my 800, 830 & 930 all bolted right up with only a slight modification to the original Gen mounting shaft. Had to change the pulley to a Ford twin v-belt kind for the Power Steering belt. The Wiring came from the scrap Ford Harness. Simply had to un-tape and pull out the wires that were part of the charging circuit, cut-em, splice-em to the right lengths and re-tape. Mounted the regulator onto the Case bracket that supports the front of the fuel tank on the 800 & 830. Amp meter still works normally.
Jim Handke
05-14-2004 06:44:15
I put an alt. & external regulator off a 196? Buick on my 830. Took it to our local alt. repairman and he showed me what wires to connect. It's easier to install an alt. with an internal regulator.
