Case 580E Shuttle problem
Paulc
05-13-2004 16:03:52
I need some help. I have a 1987 580 superE and it was running very well. I went to put the transmission in reverse and it felt like the linkage let go and sure enough it did. I reinstalled the lever arm to the shuttle and the machine goes forward in the neutral & forward positions and with the power solenoid screwed on the control shaft, the reverse is now neutral. Without the solenoid on the machine will only go forward. I checked the obvious stuff like fluid and lines and went so far as to remove the control shaft from the top of the shuttle case to look for a crack or clogged port and the area was very clean. The manual does not address this. Any ideas? I hope it is something really simple...
