Case VAI 1945 parts
John McMillian
05-13-2004 08:25:02
I have a 1945 Case VAI that I need some engine parts for, firstly a head gasket. Is this the same engine as on a VAC? I looked on the parts page on this site and did not find anything related to the VAI model, any other good parts sites that might have VAI parts?
Phillip Wilkerson
05-13-2004 17:38:53
 Re: Case VAI 1945 parts in reply to John McMillian, 05-13-2004 08:25:02
I am currently in the process of dismantling a 1948 VAI. There are some pretty good parts scrapped out if you are interested. It also has a mower attachment that I am scrapping out.
John McMillian
05-14-2004 05:39:04
 Re: Re: Case VAI 1945 parts in reply to Phillip Wilkerson, 05-13-2004 17:38:53
What part of the country are you in Phillip?
Is the hood and a rear rim in good shape?
Phillip Wilkerson
05-14-2004 06:07:45
 Re: Re: Re: Case VAI 1945 parts in reply to John McMillian, 05-14-2004 05:39:04
I live in North Central Louisiana, Winnfield 71483
about 90 miles south of Shreveport and or about 60 miles south of Monroe. I would say the hood is in fair cond. The grille with the light brackets is in good cond. I don't remember the rear rims being any good but I will check. There is one fender that is good shape the other fender does have some rust through holes. The sickle bar mower is complete but the cutters are stuck on the bar...been outside for a number of years. The rear end, tranny, torque tube appears to be good. Probably the best thing to do is call me at 318 628 6594 after 8:00 pm for a better description of parts if any of you are interested.
Art
05-14-2004 03:47:36
Morning Phillip, Where are you located, as I have a 46 VAI and would be interested in a cycle-bar mower, and whatever else you might have, if your close enough to me....Thanks Art
Wide Open
05-14-2004 18:32:12
 Re: Re: Re: Case VAI 1945 parts in reply to Art, 05-14-2004 03:47:36
Art, I have a sickle bar mower off a 46 VAI, it is in rough shape w/ some welds, but it is all complete. You can have it for free if you want it. I am located in MN.
CP
05-13-2004 08:42:19
Same from top to bottom and back to front of engine tranny and rear.
