to free heads
INCase
05-13-2004 05:10:41
Finally had a few minutes to start on the 730 engine. Took water manifold, valve cover and rocker assembly off. removed head bolts (nuts). now is there a trick to getting the head off???? I tried a bit with no luck but ran out of time... I also noticed the inside of the valve cover was very "gunky" it was almost like everything being painted black and moisture got under the paint, rusted a bit and flaked off. I believe it has sat for about 9-12 years.
Robert Pence
05-17-2004 06:47:37
 Re: to free heads in reply to INCase, 05-13-2004 05:10:41
I've had success loosening up stuck heads and other parts by bumping around them with a big rubber mallet or fiber hammer. That helps to break up rust that might be around the studs/bolts. If you don't have either, I suppose you could get by with a block of wood and a heavy hammer. Don't beat on it or hit it hard, though, just bump it firmly.
RobertTX
05-14-2004 07:11:49
Jim's advice is good. This is ususlly due to rust on the studs in the holes in the heads. Tough, but not impossible.
Jim Handke
05-13-2004 09:46:33
Try using two bars, on opposite sides, in whatever opening looks the strongest. Takes two people, maybe, rocking the head.
