marvel TSX 936 on a 440?
Dave B.
05-12-2004 19:35:41
I have a Marvel-Schebler TSX936 carb on my 440 tractor. I have taken it apart, installed a complete rebuild kit, cleaned the gas tank and replaced the fuel line, but it still leaks. The TSX936 from what i have found was only used on a model 580, could this be the problem?
If anyone knows please let me know before I try a new one. Thanks Dave B.
Glen in TX
05-12-2004 22:40:51
 Re: marvel TSX 936 on a 440? in reply to Dave B., 05-12-2004 19:35:41
Carb charts show the TSX936SL to have been used on the 440 and 480. Check the float to make sure it isn't rubbing or hanging on the side of bowl casting or has a leak in it. Can check for leaks by holding float in pan of hot water with pliers and watching for bubbles. TSX floats should be set at 1/4" from carb surface.
DaveB.
05-13-2004 17:55:12
 Re: Re: marvel TSX 936 on a 440? in reply to Glen in TX, 05-12-2004 22:40:51
Thanks Glen, I will pull it apart and check for leaks.
