Setting case 300 valves
steve
05-12-2004 18:21:29
can anyone please explain to me how to set the valves on a case 300. I just had a valve job done and need to set them. thanks
Joe (Wa)
05-12-2004 19:13:46
 Re: Setting case 300 valves in reply to steve , 05-12-2004 18:21:29
Valves are set cold. Set valves in firing order 1-3-4-2.
Turn the engine in the direction of rotation until #1 piston is TDC, adjust lash on both intake and exhaust valve @ 0.014".
Turn engine same direction 1/2 revolution (180 degs)to put #3 at TDC and set valves' lash.
1/2 rev and set #4 valves.
1/2 rev and set #2 valves.
You're done.
Steve
05-12-2004 20:55:37
 Re: Re: Setting case 300 valves in reply to Joe (Wa), 05-12-2004 19:13:46
Thanks for the info Joe, thats all I needed and thanks for writing the directions so simple, Steve
