seals and bearings for DE hyd pump
bill wilson
05-11-2004 19:17:28
Where can I buy the needle bearings and seals for the hyr, pump on aDE orshould I say ( D series combine engine) This makes a greart live hyd on older D and DC tractors Bill Wilsom ( in Montama)
C. Amick
05-16-2004 06:43:18
 Re: seals and bearings for DE hyd pump in reply to bill wilson, 05-11-2004 19:17:28
Motion Industries' web site address is motionmro.com You can go there to find the store nearest you.
John Saeli
05-12-2004 04:30:39
Hey Bill: I'd be suprised if CASE didn't have those items, but NAPA will be able to get them. We have a Carquest store here that is pretty good also.
bill 3wilson
05-12-2004 19:49:04
 Re: Re: seals and bearings for DE hyd pump in reply to John Saeli, 05-12-2004 04:30:39
Thanks John but i tries napa I wonder if any body knows if case make the pumps or if someone like vickers mde them also there is should say was a very thin plastic gasket like some pumps use as a thickness shim to set clearence This discenerated when I took it apart Does any one have a case manuel coverings the older pumps I think the vac pump is the samp except for the drive
C. Amick
05-13-2004 12:45:23
 Re: Re: Re: seals and bearings for DE hyd pump in reply to bill 3wilson, 05-12-2004 19:49:04
Have you tried anyone like Motion Industries? Do they have any stores in your area. They should be able to match up the seals and bearings for you. How complicated is the gasket, can you make one from gasket material?
bill wilson
05-15-2004 16:24:11
 Re: Re: Re: Re: seals and bearings for DE hyd in reply to C. Amick, 05-13-2004 12:45:23
never heard of motion ind have you gor a phone number The gasket may be made possibly however on some pumps I have worked on the so called gasket is also a spacer to set clerance and the come in different thickness Thanks for replying Where is this motion ind located ??
