Desert Sunset what brand should I buy?
R Wyler
05-11-2004 19:00:50
I am needing some Desert Sunset to paint my 930 hood grill and fenders and I am needing some advice on what would be my best choice. There are Dupont dealers nearby and I have a friend who can paint it for me with hardner. Is the Dupont Desert Sunset an accurate match? I want to use some that will last a long time and that is why I am asking about this. I appriciate any help. R Wyler
The Rodent
05-13-2004 19:09:26
 Re: Desert Sunset what brand should I buy? in reply to R Wyler, 05-11-2004 19:00:50
When we were gettin desert sunset to paint our case, we went to our local case dealer. Your asured the color will match, and if it turns out bad you can go get your money back.
JohnM
05-11-2004 21:13:01
I did not have any luck getting DuPont paint. Ended up with PPG. If you get it put the numbers or the formula up here, as I like the DuPont better to work with.
R Wyler
05-12-2004 05:37:46
 Re: Re: Desert Sunset what brand should I buy? in reply to JohnM, 05-11-2004 21:13:01
Hello John I looked in the archives and found a prior to 1973 Dupont code for Desert Sunset 75194 maybe if they were given this # they could cross it over to the new code. My friend does not like PPG or I would buy it because we are planning on him painting it. I will call and ask and post my info here. R Wyler
R Wyler
05-12-2004 18:20:32
 Re: Re: Re: Desert Sunset what brand should I buy? in reply to R Wyler, 05-12-2004 05:37:46
Well I called and that # did not show up in his list and he said he could mix it up if I get the # so I guess we best keep looking for it.
Paul
05-13-2004 10:55:13
 Re: Re: Re: Re: Desert Sunset what brand should I in reply to R Wyler, 05-12-2004 18:20:32
When I paint a case tractor I prefer to use paint straight from the local case dealer. It is a tough paint, and best of all it's the right color match.
