Case 600B Grove Value?
Will
05-11-2004 14:39:16
I have an opportunity to trade a 1941 Farmall H (runs good) for a Case 600B Grove tractor. The Case says Case-O-Matic down the side but has a hand clutch. The engine has had some work and starts and sounds good, but the transmission grinds and is hard to shift. Wanted to know an approximate value for this particular model to see if it's worth making the deal or not. I appreciate any thoughts on the matter you'd share!
simon
05-12-2004 17:46:46
 Re: Case 600B Grove Value? in reply to Will, 05-11-2004 14:39:16
If you need part for the 600b I have one with a bad motor Good caseamatic clutch let me know
simon
05-12-2004 17:46:10
I fyou need part for the 600b I have one with a bad motor Good caseamatic clutch let me know
caseman-d
05-11-2004 18:01:30
I would take the trade. Check the fluid for the convertor and see if it looks burnt. Always rember to idle the tractor down before trying to out it into gear.
caseman-d
