CASE 300
Steve
05-11-2004 13:39:17
Does anyone know where I can get a exhaust elbow for an upright muffler for a Case 300. also what kind of oil goes in the triple range transmission, and the rear end. any help would be greatly appreciated. steve
James Byrd
05-11-2004 13:53:44
 Re: CASE 300 in reply to Steve, 05-11-2004 13:39:17
roger hornbaker @ [email protected] should be able to help you with the exhaust and the triple range takes 12 Qts Multi-Viscosity SAE 10w-30 oil and the models 300, 310 take 13qts SAE 90 in the Transmission and the Diff. Case the models 301, 311 take 6 gal SAE 90 in the Transmission and the Diff. Case.
Steve
05-11-2004 14:36:37
 Re: Re: CASE 300 in reply to James Byrd, 05-11-2004 13:53:44
thanks for the info James
John Saeli
05-11-2004 18:59:21
 Re: Re: Re: CASE 300 in reply to Steve, 05-11-2004 14:36:37
Hey Steve: A better choice for the Triple Range Unit is Hy-Tran, or any Transmission-Hydraulic Fluid. These Fluids are designed for gears. In my 350, I add about 1 Qt of 85W140 to 3Qts of the Trans.-Hyd Fluid to give it more body. For the Tranny-Final Drive, I believe 85W140 is the best choice. In cold weather it has the flowability of an 85W, yet when hot it offers the protection of a 140.
